error c:32-11 help
profile.country.bg_BG.title
borislav1b
error c:32-11 help
my camera dyspleyed error C:32-11
profile.country.en_GB.title
Mick2011
Hi borislav1b, welcome to the Sony Forums
That error relates to the tape door mechanism. Check the door is properly closed; if you still get the error message, removing and replacing the battery sometimes helps.
If that doesn't do the trick it may need to be repaired. Sony Support can be contacted here.
Good luck
Mick
1 REPLY 1
Mick2011
Good luck
Mick
