Memory download.
profile.country.en_GB.title
peter.r.lee
Memory download.
Hi
Does anyone know if you can download photos & video from the Bloggie Touch direct onto a memory stick/flash drive while out 'on the go' without having to sync with a computer first?
Any help will be much appreciated.
Regards
Peter Lee
Watashiwateshdes
Contributor
Hi Peter Lee
Something covered in an earlier discussion but the concept still remains to give you some insight
- https://www.sony.co.uk/discussions/message/688888#688888
The problem is these have not been directly designd for import/export without the use of a computer so what you end up with would be the requirement of a photo bank/drive which would need to be powerful enough for the Bloggie.
You have two different types of devices, one which can use its internal power to leave itself switched on and the other solely takes power from the external power source when connected. If that makes sense? The Bloggie is the latter so on its own connected to some sort of flash or external drive will simply not give any response/recognition.
It may be possible that we see these on later models but I do not predict an update on this any time soon to change its USB operations.
Hope that gives you an insight.
1 REPLY 1
Watashiwateshdes
Contributor
Hi Peter Lee
