Walkman NWZ S639F problem
profile.country.en_GB.title
rutade
Hi
My walkman's battery gone flat, but when I plug it into my laptop trying to charge it, the walkman screen starts flashing  continuously and freezes the laptop. Resetting didn't make a difference.
Is it dead?
I hope - not, any ideas?
Thank you
3 REPLIES 3
profile.country.de_DE.title
frbauer1440
I have exactly the same problem. I have not used the player for a while now and it seems that the battery is totally flat. Unfortunately the computer does not recognise it, therefore I cannot charge it.
I had this problem before when the player was still under warranty and sent it to Sony UK. Apparently a firmware update was performed and the player was working for a year. Now the same failure again...
johgraha
I think I might have a similar problem .The player will not charge.I thought of trying a new battery .I've looked on the net but can't seem to find anywhere selling one. Any suggestions ?
This of course asumes its poosible to replace it myself fairly easily.
alpha4beta
On ebay uk, I think they are selling these batteries, on the page it mentions nwz-s638f red which I presume is identical to the nwz-s639f (apart from being 8 gb more).
If you do a click on this link it should give you a result, hopefully.
Regards,
Andrew.
