Wf-c500 problem with left earbud
profile.country.SE.title
FransH
Hi!
I’ve had this pair for about three months and my right earbud works but my left one has some problems. When it is in its case the left earbud is just blinking orange over and over again and when I take them out it says power on, but then it loops the phrase over and over again very quickly. I’ve tried to reset it multiple times but it doesn’t seem like the button is doing anything. Is all hope lost or is there some way to fix this?
7 REPLIES 7
HannahEd01
Hi FransH,
Try the below steps, testing after each one:
-Charge the headphones fully.
-Reset them: https://helpguide.sony.net/mdr/wfc500/v1/en/contents/TP1000449911.html
-Initialize them: https://helpguide.sony.net/mdr/wfc500/v1/en/contents/TP1000449912.html
Let me know the outcome.
Barca78
First, completely discharge the battery on the handset. And then do a factory reset
KatW25
Hello, did you manage to resolve this?  I've got the same issue, contemplating buying a left bud only off ebay.
Ferperezv
Hi!
I'm experiencing the exact same issue. The left earbud does not respond to any commands. It is not possible to initialize or reset it.
Has anybody been able to fix this?
TheMaze
Hey, the steps here usually fix most issues with this headset: https://www.sony.co.uk/electronics/support/articles/00271326
Try them and let us know
Sintia
Still haven't resolved the problem. Any other ideas?
TheMaze
If the steps there didn't resolve the issue, then unfortunately you might need to take it back to the retailer if still in-warranty.
