Bonjour excusez-moi mais c'est possible de transférer les applications sur une carte microsd ?
No, this has been changed by Google.
Donc c'est impossible de mettre une application sur la carte microsd ?
So it's impossible to put an application on the microsd card? - GT
Hi @Julian13,
Your question has been translated to English as this is an International forum, please post any replies in English and it will be easier for me and other users to assist you.
As @Strampke wrote, this is not available in our devices starting from the Xperia XZ Premium and onwards.
Keep in mind that some applications may be able to store data on the SD card, such as offline playlists, downloaded movies/TV show, offline maps and so on. If you have a lot of downloaded music/videos, take a look in the settings menu (usually found if you tap the three lines in the top left corner) for these applications and see if you can transfer the data over the SD card instead.
Let us know if that helps!
Ok, thank you and well I find it silly and shameful on the part of Sony regressed to himself without thinking of users. It was the goal of a micro SD card. And one more than Apple did not have. I have a 64go micro SD card and it is useless, I regret my purchase. If Sony sees that corrected that please and stop this kind of stupid error.
Hi again @Julian13,
I'm not quite sure about the reasoning behind it but I'll make sure to forward your feedback about this not being available.
I use the SD card for offline music, podcasts, photos and videos so I use around 30-35 GB of storage there which helps a lot, but I don't have any big apps or games on my device.
