- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Xperia 10 freezing at deleting cache
Hello everyone,
I have the following problem with my phone:
For a few days, Chrome sometimes freezes for a few seconds and then the message "Chrome has stopped responding" appears. After a short wait, the phone responds normally.
As I tried to clear the Chrome cached data through the Apps settings, the phone crashed and reboot, even showing a white triangle with wrench. Now, the phone seems to be working normally again.
What is the problem with clearing the cache? Since I have got this phone I try to avoid clearing the Chrome Cache, Since it generally tends to crash the phone easily.
Thanks for your responses 🙂
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I had something like you suffered from.
Chrome completely unresponsive.
After an update of Chrome in the PlayStore it's over.
If you want to clear things up a normal reboot will do.
If you want to clear cache as well then force stop the device.
- Press and hold down the power key
and the volume up key at the same time for 6 seconds.
- Your device vibrates once. Depending on whether you wish to force the device to restart or shut down, proceed as follows.
- If you wish to force restart the device: Release the keys at this point. The device restarts.
- If you wish to force shut down the device: Continue pressing the keys. After a few more seconds, the device vibrates three times and turns off.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
thanks, I will try that
