Xperia 10 SD card unsupported
Clockworks
Just put sd card into phone, settings had me format the sd card and then it shoes its unsupported. It works on other devices.
10 REPLIES 10
Jonas
Master
Hi @no13benny, sorry for the late reply, I have been out of office due to vacation.
Does the SD card still work in her old Xperia device? There isn't anything different in the Xperia 10-series compared to older devices, the same type of SD cards are supported, just a bigger size as the device is newer.
If the SD card reader is defect, it will be the same with a different SD card so I can't promise that it will work with a brand new one. Do you or your wife have the possibility to just try with a different SD card? Perhaps if you can borrow from a friend, colleague or family member before you spend money on a new SD card.
Let us know how it goes!
