Do not disturb not switching off
TheAppEffect
My do not disturb is not switching off when I use an automatic rule. If i activate the rule sleep, it will turn on do not disturb at 22.00 but when the time reaches 6.00 am and it should turn off, it do not turn off?
This is the same if I create a new rule..
Anybody got some idear what to do to fix it?
13 REPLIES 13
TheAppEffect
Anybody have a good surgestion?
RottenFoxBreath
Enthusiast
The automatic rule Time which is standard, with no editing, turns off at 0730 not 0600.
TheAppEffect
Ok i'll try to change it back to 7.30 to see if that works. But it should work when I creat a new rule, but it dosen't. So there is something wrong.
RottenFoxBreath
Enthusiast
So youi want to make sure it's set to time, and 0730.
Agnes_C
I have same problem too.
I create a new rule and it didn't switch off after the end time.
And also happen at one time do not disturb mode, I set 1 hour and it didn't switch off automatily.
Is any solution?
TheAppEffect
Hi, I have not managed to solv this yet.
so I'm hoping Andoid 10 will will this very anoying problem.
I have tried to reset the phone to factory setting and that did not help either.
TheAppEffect
Was not fixed in Andoid 10 😞
GillRogers1
It doesn't turn of for me either.  I have 2 set for different days.  I've deleted them and made new ones and they don't turn off either.
GillRogers1
Has anyone solved this?  Sony have told me to send my phone back.  Surely not. ☹️
