Feature- and Security-Updates Xperia 5V
SonyXperiaUser
I want to switch back from an iPhone to a Sony Xperia.
I'm planning to buy the Xperia 5V because it has good specs and isn't too big. I don't like large smartphones because they don't fit in my pocket. The phone was released in 2023, and now it's 2025. Until when is it guaranteed to receive feature updates like new Android versions, and until when will it get security updates? I plan to keep the smartphone for at least 2 or 3 years. Will I get updates until 2028, or until when will I receive them?
Thanks in advance for your feedback. I'm looking forward to your reply. I'm so excited to get back to using a Sony Xperia! 🙂
Also, can you maybe recommend another Xperia smartphone of nearly similar size and specs that might receive updates for a longer period?
Best regards, SonyXperiaUser
2 REPLIES 2
MaggieGreene
Hi @SonyXperiaUser, the Xperia 5 V will get updates until September 2026. I'd recommend getting the Xperia 1 VI as it has Bug Fix & Security Update Plan for 4 years until 2028 as you wish, and it's smaller in size than the Xperia 5 V.
Here's a comparison link between the Xperia 5 V and the Xperia 1 VI to help you decide the best one for you: https://www.sony.co.uk/smartphones/compare?cpint=gwx-all-smartphones
SonyXperiaUser
Hi Maggie,
thx. for your reply.
I am a bit confused, you write that the 1VI is smaller but it is not smaller, it is bigger.
Maybe you mean another model?
 Thx. in advance for your help.
    Besteht regards.
