Xperia 5 ii camera is noisy
Victor_ZVV
Hello!
Are there any Xperia 5 ii owners?
Have you paid attention to camera noise? With the Xperia 5, I didn't notice this noise.
It is quiet, but still there. It is noticeable especially in silence or when you bring it closer to your ear. This noise remains in the recorded video. Cannot be heard in a noisy place.
There is a slight click when turning on the camera.
Is this a defect?
Thank you  for your response.
Victor.
Tags (2)
15 REPLIES 15
CosmicTomato
Specialist
My guess would be that these are the tones the phone plays to declare audibly that a button had been pressed, like the keyboard sounds.
Pavel.i
The noise comes from the camera's stabilizer.
This sound makes me happy as a photographer. I can’t check now, the phone has just been bought, but it’s already under repair
Victor_ZVV
The noise really comes from the camera stabilizer.
But it bothers me that there is more noise than in the Xperia 5. Working with the Xperia 5, I had no idea that there was noise. But when I turned on the camera on the Xperia 5ii, I immediately heard a distinct noise. Noticeably noisier.
And further. When shooting with the Xperia 5 in low light, the video is brighter but dimmer than when shooting with the Xperia 5ii. In the latter case, there is more noise in the video files.
Maybe that's the case in my Xperia 5ii?
Maybe I need to customize the Xperia 5ii?
All video recordings are made in the standard application.
This Xperia 5
Xperia 5Xperia 5
This Xperia 5II
Xperia 5IIXperia 5II
Pavel.i
First screenshot - More noise reduction work, less detail. The second is the opposite. It is right. Over time, you can install a third-party application that will allow you to change settings and not overshoot the ISO whenever possible.
Victor_ZVV
Thank you for your prompt reply.
So, in general, Xperia II 5 worked better?
Pavel.i
Yes, better
Pavel.i
But you need to shoot lighter
Victor_ZVV
What happened to your smartphone?
I have already exchanged my smartphone for a new one. In my first Xperia 5, the speaker reproduced some frequencies poorly (rattling sound).
Victor_ZVV
In my Xperia 5II on the video in the twilight, the brightness jumps. Sometimes brighter, sometimes dimmer. I do not know how to fix this.
Is the processing slow? The software can still be raw? I installed the picture, after 7 seconds it changes to a dimmer one. I slightly shifted the camera towards the lighter side, the brightness increased.
