- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Xperia 5 wont boot fully, also startup screen is green instead of black
I cannot access my phone for some strange reason, when I try to access the phone it restarts, but wont fully reboot. So basically it keeps going round in a loop. Also the startup screen appears to be a bright green colour instead of black, 😫
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You can start by checking if there is a faulty SIM or faulty SD card inserted, which was mentioned over here.
Next follow the path indicated by Sony Xperia Support.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Good Morning
Thanks for the response, I'm afraid none of those options worked 😞
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
That's a pity.
One last option:
Charge the device to > 80% and switch it off.
Open Xperia Companion, choose Software Repair.
On the next page tick 'My device cannot be detected or started, or is a SmartWatch 3'
Click Next and follow the instructions. (see the picture: Capture.jpg on the right)
Hope it works.
PS
When a device fails the normal answer would be: open the Support app on your device and tap 'Contact us', the smartest way to contact local support.
In case the software repair fails contact Sony Support starting here.
