๐๐๐ฅ๐ฅ๐จ ๐๐ฏ๐๐ซ๐ฒ๐๐จ๐๐ฒ ๐๐จ๐ฅ๐๐๐ง๐จ๐ฐ๐๐ข๐ ๐ก๐ญ ๐ก๐๐ซ๐!
**๐ ผ๐ ฐ๐ ๐ ผ๐ ๐ ฒ๐ ฐ๐ ผ๐ ด๐๐ ฐ ๐ ฑ๐ ด ๐ ณ๐ ด๐ ต๐ ด๐ ฒ๐?**
I have been asking myself this question, now for a long time.
Might my camera, be defect?
The camera overheat & crash after 5-8-minutes, after having this issue & problem for almost 1-year with my camera.
I used - microcard - 200GB SanDisk Ultra microSDXC Class 10 UHS-I 100MB/s A1!
I changed it to a, Lexar MicroSDXC 64GB UHS-II U3 1800X, 270MB/s!
Now it can hold for 20-40-minutes, but it still crashes or overheat.
Also the 4k look more worse then my HD, so I start to wonder.
Maybe the camera is a defect-camera?
Or might there be another reason?
My Jupio batteries - Sony NP-BX1 these two batteries are always empty & they drain themselves & are empty if I don't recharge them every time - The original Sony better do the same.
Is this also a normal issue?
I paid 1000 euro, for the Sony-FDR-x3000r camera kit & I can't even use it.
Since the camera crash after 20-40min, it overheat or it started to glitch on the videos.
I did contact www.proshop.se & they refuse to fix the issue or the camera.
But later on they said okay, send it in all the way to Denmark that will cost me a lot of cash.
I still haven't sent it in, since their attitude where bad & the support was horrible.
So, my question is?
Might my camera be defect-camera?
Now, I had a video on this on YouTube.
But removed it, since it made Sony look bad.
I might make a new one, just to see what people say.
Any info about your own - Sony-FDR-x3000r!
Would be great thank you!
Thank you note!
๏ผฃ๏ผณ๏ผฌใ๏ผใ๏ผฏ๏ผต๏ผด!
Hello @ColdSnowLight,
would you please upload the video again to YouTube? It would make it much easier to identify if your camera is defective or not.
Do you use it with the housing or without when it shuts off due to heat?
Yes, batteries drain themself if you have the bluetooth-standby switched on - the camera always creates a bluetooth point, which you can connect to and remotely switch it on, that drains power. Without it you can store your camera away and it will keep its charge for many days (easily over a month).
- Nic
๐ ฑ๐ ธ๐ ถ ๐ ต๐ ป๐ พ๐ ผ๐ ฟ๐ ๐๐ ฝ๐ ธ๐ ฒ๐ พ๐๐ ฝ๐!
๐๐จ ๐๐ง๐ฌ๐ฐ๐๐ซ ๐ฒ๐จ๐ฎ๐ซ ๐ช๐ฎ๐๐ฌ๐ญ๐ข๐จ๐ง๐ฌ!
*๏ผฉ๏ฝ๏ฝ๏ผฎ๏ฝ๏ฝ*
๏ผ๏ผญ๏ฝ ๏ผ
Question 1: I could upload the video again, but then I would have to change it.
Since, I have more evidence now with other issues.
Question 2: I do not use a housing!
Question 3:Ah yeah, no, it drains itself even when it's in my bag, I have to recharge it every time even if it's not in the camera.
Thank you for the repsond - Nic!
CSL & OUT!
