Finding my model on A7 camera
Borderer
My camera label only says ILCE-7, with no additional model details - is there a way of finding the exact model via the serial number? I bought it in 2019
5 REPLIES 5
danardeng
Contributor
Look at the label on the bottom plate of the camera.
If it say “ILCE-7”, finally yes: you have a A7
PS: what model you expect to have?
Borderer
I had indeed looked at the plate on the camera and I knew I had an ILCE-7.
However I was trying to use the connection facility on the Sony 'Creators App', and in the setting up it asks for your model and lists compatible models - the list has ILCE-7RM5, ILCE-7SM3, ILCE-7M4, ILCE-7CR, and ILCE-7CM2 among other models. There is no basic ILCE-7. I don't know if my camera is actually one of those sub-groups and this is not shown on the label, or whether it's just an earlier version. Hence the question.
danardeng
Contributor
No, for sure you can’t use creators app.
Probably nor the old imagingedgemoblile.
Maybe the oldest playmemories (if you can find it)
Borderer
Playmemories has basically stopped but I have the rather more clunky solution of using Imaging edge to transfer shots to smartphone/PC while using the Camrote app to do remote control.
It would have been nice to have Sony software or app that could actually do both properly but then I did buy a Sony...
Thanks for your replies!
danardeng
Contributor
You had buy an iconic camera, it has 11 years old, and from 4 years it’s discontinued. So it’s an hard work to find something still compatible with it’s software.
You have to try in old apps (if you find something compatible with today smartphones) or some third party app
