Hello
It would be great to be able to get frame guide shading in the options, when monitoring from the camera without an onboard monitor.
For example, if you are filming in a frame guide ratio of 2:35.1 it would be great to have the option of shading around that frame guide so you can see the true frame you are wanting to film. Maybe in increments of 25%, 50%, 75% and the 100% shading.
This would make it a lot easier to film and frame up on the subject in the custom ratio you are filming in.
Thank you!
