2015 Bravia Android TV Issues
NickCo1979
6,373 REPLIES 6,373
Bar--8
Update: I rebooted my TV (plug out) this AM and the diabolical picture has improved to that which I remember after taking it out the box (the misses gave it formal pass too). Seems like another degrade over time issue. Might stick the set on a timer plug if this continues.
Game mode is still bad (but not as bad as it was).
NickCo1979
I'm still having to reboot at least once a day due to the sound and picture lag issues. Hopefully it's just buggy firmware. Apparently Sony will be bringing out new FW for these TVs on the 15th June (ish) that addresses the Netflix issue (as per previous post), hopefully it'll also address what seems to be memory leaks or just rough code that's causing these issues over time.
MikeLothian
That's great news, thanks for letting us know
Risc0n
Contributor
Anyone have issues with the flick remote stop working? It was fine, now nothing happens when i press buttons. Tried a factory reset and tried to register the remote but nothing happens?
Abercrombie
I had exactly the same thing happen with my remote. I called the Sony Support UK phone number, which I got from the "Contact Us" link at the bottom of the page. They offered to send a replacement once I'd emailed proof of purchase over. That was on Tuesday & the remote still hasn't arrived as yet.....
Risc0n
Contributor
At least I am not the only one! Can't understand what has caused it to stop!
Abercrombie
My remote stopped working after a factory reset as well. You might have some luck re-initialising your remote, as per this article: http://sony-eur-eu-en-web--eur.custhelp.com/app/answers/detail/a_id/68153
If you get this to work, you should then be able to pair the remote with the TV again!
alellio01
Does anyone else get the feeling these android tv's are more trouble than there worth.
I'm having to reboot mine every day, just to be able to watch it.
Risc0n
Contributor
Thank you Abercrom!!! This fixed my issue and the flick remote is now working again.
Bar--8
Seems we are beta testing these TV's, perhaps Sony might like to compensate us for the usability feedback, lack of functionality, bugs and hassle.
Would someone mind testing Game mode please (found in Action Menu > Picture > Picture Mode)? Mine doesn't work and i'd like to see if this is a unique problem.
