2015 Bravia Android TV Issues
NickCo1979
6,373 REPLIES 6,373
frogger38
@kabedin28 It seems a lot of people suggest ther is a need to do a factory reset after an update.
The problem is that at the end of the update your apps and custom configuration are intact but after the factory rest All apps you have installed and any setting changes you have made are lost.
Product is is Sony 2015 KDL 43W805C Android TV, UK Model with YouView, purchased Sept 2015.
profile.country.IE.title
EggDublin
Yes, casting is back for me too - happy days! :tongue:
In the end I brought my 55X8509 back yesterday as I was really worried about the crackling sound it made and the temperature of the base of the unit (it was very hot to touch). As was said earlier in the thread, they are blaming a faulty PCB for this which causes the TV to overheat (Sony told the shop this apparantly). I exchanged it for a new one and the crackling issue is not on this one and it runs at a normal temperature.
All in all the replacement 55X8509 is much better and also the new firmware has sorted a lot out. There's still a number of annoying issues and missing features which I hope will be sorted soon Sony.
SingingDwarf
@Anonymous No, its not the batteries or a stuck key unfortunately!
Shalendran
@Anonymous
Hi
I tried Kodi but since I am using a network hard drive I am unbale to specify the path to the folders. any ideas?
mikedino
Excellent news on the Casting working! Very quick response from Sony too.
haberdavid
When i am Casting youtube from my android phone to the tv i hear on the tv only the sound but there is black screen with no picture. anyone has this problem?
I watched Beast of No Nation on Netflix yesterday, and everytime I paused and pressed play again, a loud "bzzt" / buzzing sound would appear out of my surround - the same with 5.1 content on Plex, but not when I use the Sony Video app?
The wierd thing is, that the issue doesnt appear in the store...
theshamelessmanc
@NicolaiLarsen91
Same here! Was watching some stuff on Netflix last night with surround on, every time I paused and restarted I got that sound.  Same with SKY!
frogger38
Not sure if this is a bug / by design or 'nice to have'..
I use a Bluetooth mouse and keyboard which works well with my 43W805C, when using some apps such as Opera browser. But when using the Home screen and some other apps, the mouse buttons do not work although the cursor does.
@theshamelessmanc wrote:
@NicolaiLarsen91
after you installed the Android 5.1.1 update, did you reset your tv?
I didnt with mine, but the ones in store was all reset after the update - maybe thats a "work around fix"
