2015 Bravia Android TV Issues
NickCo1979
6,373 REPLIES 6,373
ezeest
Similarly on the PS4 the Bravia app which allows you to control Bravia TVs with a dualshock controller no longer works it can find the TV on the Network but when you try to connect it says it doesn't exist and to check the network again. Appears to be yet another BUG!
EsePoppa
I have 55x8509C and Samsung soundbar.
Connected optical and hdmi.
Sometimes when I switch sound to soundbar there is no sound.
However, when I go back to Action menu and select sound, the sound outputs from the soundbar.
No need to select any action.
andrewsoong
Is no one else wondering what and why the Opera TV store appeared for? What is that, a store in a store? Really bugging my ocd.
MikeLothian
It's just an alternative to the Google Play Store
andrewsoong
Just a shame all this rubbish isn't optional. If all the forced apps were removed the TV would probably run far smoother.
mk1.golf.1983
I 2nd that ^^ we should be able to remove the stuff we ourselves don't use or want instead of it clogging up the system. Oh an Email client would be nice considering I needed to enter my Gmail address when first intalled the tv.
kabedin28
I made a complaint today with Argos about my KD-43X8305C, telling them that in thier catalogue it says that USB recording is available when you buy. I told them that is currently not the case and that it will not be available for two months at least. They said I can return the TV even though I no longer have the box.
Are there any recomendations for an alternative 4K TV from Samsung etc. that anyone can recomend?
Ezhan1
Does anyone have a problem TV loosing the WiFi connection? Actually it shows "Connected", but no internet is available.
Helps:
- rebooting the TV (7+ sec on the remote's off button)
- setup the wifi onece again
Hoped that the update will fix it, but it did not.
SDCEGavster
For what it's worth
KD-55X8507
Problems after the firmware update:
1. Intermiitent inabiilty to connect to the internet via Wifi, even though in Settings the TV blatantly can see my network, but when I go back, it's connected.
2. After viewing my PS3 on HDMI2, I switch back to HDMI1 to view my Humax Foxsat box, the TV becomes totally unresponsive. No picture, no Home page. Can't even turn it off. Have to switch it off at the wall. Even when that is done and turned on again it has still remembered the Speaker setting that was switched to Audio system!
3. When viewing PS3/Blu-ray via HDMI2 there was no surround sound through my Sony DA3300ES amp until I ran a full speaker set-up test. Only then did it work. What's the betting it won't work next time? How is that even possible?
Other than that, the TV is running perfectly!
ZombieFried777
Mine now works after the tv was updated it never worked before, it used to find the tv but always said the tv needs updating, now it works, I don't like it though I think I'll stick to my sky remote,
