2015 Bravia Android TV Issues
NickCo1979
6,373 REPLIES 6,373
basstaeter
Hi there is a work around, you need to change to using your harddrive rather than the RAM for caching in Kodi, you find a solution here: (Zero Cache)
https://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0CBwQFjAAahUKE...
fglundgren
I think that since the last update, my Bravia Sync with the PS4 has stopped working.
It worked before, but now, it doesnt show up in the list of sync devices.
Anyone else seen this problem or maybe know a fix for it?
frankie1g
New issue for me today.
TV was turned off as normal last night. This morning TVs LED flashing red?
TV booted to spinning balls and android screen.
No real changes to tv by now touch pad remote not working and i cant pair it or unpair it.
Does anyone know what the flashing red led means and hoe to get remote working again.
so feed up with this tv
risp123
Sounds similar to my HDMI problem. What works for me is to unplug all cables fro mthe tv, wait 5-10 minutes and then plug everything back in. However this is a temporary solutions, sometimes it works for minutes, sometimes even for days. But at one point the TV won't recongnize the HDMI device anymore and you have to unplug everything again.
I'm glad to hear that the problem also happens with a PS4 because Sony keeps telling me my devices are incompatible with the TV. (Although it works for days sometimes)
Anonymous
Not applicable
@frankie1g - The flashing red LED light normally indicates a hardware fault with the TV.  The number of flashes (or blinks) determines where/what the fault it.  Unfortunatey on Sony and Authorised Technicians have access to the 'blink codes'.
Suggest you unplug the TV from the wall for a couple of minutes and try again.  However if you still get the flashing red LED - you will need to contact your retailer to initiate a replacement/repair.
andipr
@frankie1g - following up on what Quinnicus said:
Youtube might have the answer - I just tried a search for "sony android tv red error codes" and there's plenty of vids on there regarding different amount of flashes. Not sure if they are consistently applied throughout the different models and years though.
My Model KD43X8309CBU
Anonymous
Not applicable
As andipr has said - there are various blink codes on the internet.  Unfortunately the codes are different for each years tvs, as well as variations between the models themselves.
Folkfanger
Well flushed with success at having managed the update the other day I decided to tackle a slight difference between sound levels between my sat box and my tv tuner (both going to a sound system).
Big mistake. Before this it was all working beautifully. The tv turned everything on/off and the sound was output through the sound box.
First, the sat box started to come with no sound and needed a touch on the volume control to fire up sound. Then the sat box lost sound. Now I have no sound from either the sat box or the tv when using the sound box so I am having to listen through the TVs speakers.
I've made every adjustment I can find, including restting the TV sound to factory default although I don't relly know what I'm doing but. but nothing.
The control goes to the sound system, you can see the volume control on it go up and down etc. but not a peep.
HELP!!!
Shalendran
@Folkfanger
I had a similar issue. You may try going to 'settings' and then clicking 'initial setup'. You may skip the tuning process though.
Folkfanger
Thanks, I'll try that when wife finishes catchup on corrie, missed due to meddling.
