1) Hot Swap HDMI doesn't work - manifested by no input on HDMI channels 2, 3 and 4 on the KD-49X8305C. Workaround - reset the TV, either by holding down the remote power button for 5 seconds or by switching the TV off at the wall and then back on again. Further details on this thread: https://community.sony.co.uk/t5/televisions/kd-49x8305c-hdmi-2-3-4-inputs-not-working/td-p/1944435
3) Netflix App doesn't work - this seems like the app has been deliberately disabled. So far a support case has only recommended that a factory reset be performed (took two days to get to that cracking piece of advice.....), with no improvement as a result. A temporary (albeit for advanced users only) workaround is provided by MikeLothian on this thread - https://community.sony.co.uk/t5/televisions/netflix-support-for-kd55x8509c-android-tv/td-p/1945360
Wills b.
Well said
Since last update my 8509c won't go into standby unless rebooted first! Swapping to and from home screen is also very slow 10 seconds+ (my old 2012 nexus is much faster at everything android!!) sony support not responding to emails, and they are never open at useful times of day or week- normal weekday office hours only....since when has that been good customer service??! Also no freephone number.......Sony are a farce and laughing stock. Why oh why did i buy the tv......well panel is pretty darn good! I've tried all settings under the sun and several factory restores.......just need to start standby proceedure 10 minutes early EVERY time
also been waiting a year now for sony to fix amazon and video streaming locking up my blueray/htk system.....and counting.
perhaps android v6 will kill or cure?
Not happy with product, service or fact i spent £2600 and waited ages for arrival, got scammed by sony online store (took payment from my account and then advis ed 3 month delay....no refund......until i chased and cancelled order....they did ask why and they soon learnt why!) on something that has never worked 100%........refund Mr Sony??
But twice burnt=now learnt never ever to buy or reccomend Sony again......only been an avid supporter for 40 years......
Come on Sony, have an epiphany moment and get yourselves and products sorted! Please!
I've recently purchased a KD-55X8507C Android TV and with the deal came a HT-CT80 Soundbar, problem is...it keeps turning off after a while 10-15 mins.
This occurs with either Optical or Analog outputs. It like as if the Soundbar doesn't recognise that the TV is outputting any dound, but it is.
Also, when trying enter Home Cinema setup, it says the soundbar isn't compatible with the TV, which is kind of stupid since the TV comes with the soundbar.
I'm sure that I'm not the only one experiencing this, I hope to find a resolution to this problem.
Thanks.
I have a 55 inch 1080p SONY tv that enable me to play H264.mov from my iPhone, I would like to replace it with a 4K UHD TV but SONY blocks 4K DLNA, DLAN should not bother about the type of file streamed, so it is SONY that decided that customers where childs and would not understand possible lags on wifi or slow networks.
I understand that 50mbits or even 75mb flux should go preferably through 1000Gb wired Ethernet, and I do not understand that SONY blocked DLNA, so this is a marketing limitation!!!
I sent a message about it to sony support, if no response, i would be obliged to buy a Panasonic that enable 4K o
@louis8888 wrote:Hi,
I understand that 50mbits or even 75mb flux should go preferably through 1000Gb wired Ethernet, and I do not understand that SONY blocked DLNA, so this is a marketing limitation!!!I sent a message about it to sony support, if no response, i would be obliged to buy a Panasonic that enable 4K o
All of Sony's tv's since 2012 support DLNA with about 95% of all avaiable file formats, the 2015 sets is no exception. 4K video with H264- and H265-codec plays flawless on both wired and wireless here (I use it daily)
The "bottleneck" is your iPhone, it does not support DLNA sharing features like Android and Windows devices does.
I have done a factory reset and it seems to have resolved the issue. Now i am able to have control of my audio system but not with the sony remote though. Before the update i could do Bravia sync and see all the settibgs of the audio system.
I too have the stuck remote syndrome. When that hppens i just leave it for 30 seconds or until it starts to respond. If we try to do something when the Remote is stuck, there is a chance that the TV might reboot. I have noticed it a few times.
