2015 Bravia Android TV Issues
NickCo1979
6,373 REPLIES 6,373
ATROCIOUS
I'm not usually one for posting negative feedback, however, I feel compelled to share my bad experiences with the SONY x85 55" Andriod TV's and Sony support team, like many others have done on here.
My new X85 Andriod TV(s) came with numerous issues that prevented me from being able to use them for 2 months until Customer Services finally decided to replace the unit.
The issues are best explained as:
  • NETFLIX not working
  • TV took 1m:45 seconds to start up each time (black screen)
  • No Internet browser
  • TV freezing randomly
  • Poor TV resolution
  • TV randomly turned itself off
Regardless of reporting these problems within the 28 day return period, I was pulled from pillar to post over a 2 month period with the SONY Support team/Customer Services whilst i was taken through the motions of 'having to prove' these issues existed so that they could authorise a replacement unit.
I was informed by Steve at Customer Services my Android TV was the only TV with the aforementioned issues, irrespective of the numerous complaints posted on the SONY Community website experiencing the same issues.
I was made to provide evidential pictures of all the faults inclusive of videos and send them into the SONY support team, and take 2 days early leave from work so that I could 'fit in' around the SONY Support teams working hours. SONY Customer Services responded appallingly and they will not allow the case to be escalated as the buck stops with them (no management was made available to me after numerous requests). Since my TV was replaced last week there has been no follow up to check on the status and there has been no apology offered for the inconveniences caused.
This has been an horrendous experience and I could go on to explain further complaints, however, I would urge anyone who's thinking of buying a SONY Andriod TV to steer cleer until such time the Android TV is out of BETA testing (that's clearly where they have been since being made available for purchase).
profile.country.en_GB.title
tweety2b
Ex Commander (Was always on)
Hi @ATROCIOUS
Have you upgarded to the last firmware? The Netflix and Internet browser App got added/updated on a later update.
As you are saying the internet browser isn't there, my gut feeling says you are not running on the latest update.
Go to Settings -> About and then SW update.
Nico
Nico Henderijckx
(ex-Sony employee - fanboy forever)
jwq001
@tweety2b wrote:
Hi @ATROCIOUS
Nico
Must say that, on my 55x93 I have the latest software, and at least once a day it does a spontaneous reset....
Also, if I don't switch of the mains at the end of the day, it refuses to start up next morning. I have to pull the plug and restart it....
Apart from that the picture is great.....
Nibor99
Hi!!
I am hoping that someone be able to offer some help and advice.
I purchased a Sony KD43X8309CBU about 14 days ago from Currys and have struggled to get a satisfactory set up for what might be called regular TV viewing including sports like Tour De France and motor racing F1.
Practically ALL the presets (apart from Photo Vivid) are soft / out of focus (and I have both updated the software and used factory settings)
The supplied Currys "Knowhow Picture Perfect" CD has proved helpful as has the "My PicturePerfect "website (AV Forums) but I still haven't been able to get the good definition I feel the TV is capable of. Also I am getting unwanted artifacts on panning shots as well as shimmering - eg on helicopter roof tile shots (Tour de France) / motor racing crash barriers and even panning shots on BBC HD newsroom programmes.
I am using HDMI 1, have highest quality leads and the source is Virgin Media.
1. I am beginning to wonder if the TV is faulty.
2. Has anyone else had problems with soft pictures and if so how have they been overcome.
3. Will adjusting the resolution setting help?
4. Should I return the TV?
I have included a settings record which I have been using to help track down the best settings - if someone would like to jot down and return their preferred settings it would perhaps give me a clue as what to try next.
I am looking for sharp, natural colours without any motion artifacts.
Many thanks for reading about my issue and I hope someone will be able to help.
Robin
SONY 4K TV Settings
Channel:- HDMI 1
Date:-
Mode
Auto Picture
Brightness
Light Sens
Colour
Advanced
Brightness
Brightness
Contrast
Gamma
Black
Black Adjust
Adv Cont Enhanced
Colour
Colour
Hue
Colour Temp
Avcd Colour Temp
Live Colour
Clarity
Sharpness
Reality
Resolution
Rand Noise Redn
Dig Noise Redn
Motion
Motionflow
Film Mode
Advanced Col Temp
R Gain
G Gain
B Gain
R Bias
G Bias
B Bias
Gain advance point
R Off
G Off
B Off
Abercrombie
Try these settings for the x830: http://www.rtings.com/tv/reviews/by-brand/sony/x830c/settings
Sent from my iPhone
dspencer999
Is anyone else experiencing excessive pinks on faces?
It happens intermittently, but then looks like everyone has got some kind of radiation poisoning!
Viewing close up, I can actually see the pink blur flickering on some level. I've now changed the settings in line with those suggested by Abercrombie, and it still happens.
Anybody else? Or is mine faulty?
Nibor99
Abercrombie,
Many thanks - I will explore the settings!!
Robin
chpetzn
I've had a phone call from Sony to apologise for the way I was treated, in return, I've removed the link to the story...
Chris.
Anticitizen0ne
Just to add to this After 2 weeks I got an update from 3rd tier of support for my TV and I dont think Ive ever been more insulted.
"please make sure whe your updating your TV, your tv is not near and thing that gives out radio waves. Eg a Microwave....."
"Also make sure you do it via LAN."
2 weeks for that. WHAT. A. JOKE.
To top it off the guy I spoke was so suprised at this response.
Literally the worst customer support Ive ever experienced. Iver always been a Sony guy but this is pretty much enough to never buy Sony again.
JulianALB
I have to add my voice to the chorus of complaints about these new sets.
I purchased a KDL-50W755C in June 2015 and have been through 3 firmware updates so far.
I am getting pretty tired of having to reboot my telly as often as I do, it shouldn't be this difficult to watch the TV.
The Lip Sync on this product is awful for HDMI video sources (with or without a sound bar).
The DNLA streaming though the internal Video App is poor and can regularly not 'see' any DLNA devices on my home network. There are several other Sony TV's on the same LAN that can comfortably detect and stream video from the Synology server I have used for the last three years.
I am at the point of returning this set and buying a different TV.
