2015 control on late 2016?
profile.country.NO.title
zelder
Hi. I have a XD8005 Sony Android tv. I've lost my remote, and it looks like a new one is $60+.
Does anyone know if the SONY NFC RMF-TX100E will work on newer TVs?
2 REPLIES 2
Unfortunately it doesn't - you need to have the RMF-TX200 for the late 2016 models.
Peter
Anonymous
Not applicable
Hi there
I believe that remote control will not work with your TV model.  It is always best to get the correct remote control for the TV.
A search for the RMF-TX200E indicated that its about £45.  Although as you mention $$, you may not be in the UK :slight_smile:
