A80J 4k 120hz Dolby Vision
kelvishi
Hi was just wondering if the A80J will have support for 4k 120hz Dolby Vision in a future software update or if it is a hardware limitation?
rooobb
It seems that any TV using the mediatek soc cannot manage Dolby vision and 4k@120hz at the same time. So I  guess is hw related.
3 REPLIES 3
rooobb
kelvishi
Do you think this will be a concern if I am only using a PS5?
rooobb
Ps5 does not support Dolby vision at all :wink:
