a80j/a84j software update 6.57701 issues
kev1ns
My oled software updated and now i'm having issues using the last input source after turning the tv off and then back on again!
I turn the tv on watch netflix or freesat turn the tv off, come back to tv later turn it on now netflix or freesat won't launch via direct buttons on remote or via apps... only way to get them working again is to restart the tv.
How can i roll back the software update? it has broken my tv!
2 REPLIES 2
You can't roll back, try a reboot of Android TV (keeping pressed Power/OFF on Remote) or try the Factory Reset (a Factory Reset can risolve this type of problems).
HannahEd01
Hey kev1ns, what's the software version? Also, try checking the inputs menu and see if there's a setting that might help.
