Does anyone know how to add catch up programmes on the youview guide with the A95L remotes (either the premium remote or the standard one)
I don’t see the record button, which you would normally press on the youview guide to add to MyTV.
Thanks
@Talljed Did you have an external HDD device? check this article I've found on Sony website it will help you: https://helpguide.sony.net/tv/kaep2/v1/en/03-01_01.html. After that you can check this link, it will tell you how to record on the guide: https://helpguide.sony.net/tv/kaep2/v1/en/03-01_03.html
