Approx. Every other day my Bravia XR A95K TV asks me to set up my HT-A7000 with acoustic center sync. Does anyone else experience the same thing?
hello @TheRealKjalarr
have you tried to sync it properly so it wont notify you ?
https://www.sony-asia.com/electronics/support/articles/00283637
Of course I have 🙂
Have you tested it with different cables or ports? Did you check the software for both the TV and the sound bar? What's the version installed on them?
Also, try to forget or reset the connection and do it once more.
Yes and everything is up to date
Hey @TheRealKjalarr, does that happen with different cables as well? What's the exact version of the software? and when did you notice this issue?
Yes 🙂
Hey @TheRealKjalarr, have you checked the exact software version on your TV? Maybe the TV doesn't recognize the latest version yet, it should be version 6.6495.
Everything is updated 🙂
