Alexa app on help menu
MikeSmartv
I have just updated to 7.0  nougat on my KD55X8509C  tv . I have a few problems
1 . No internet via wired ( only WiFi)  worked fine wired before update
2. The Alexa app not present ( 7.0 nougat shows app in help menu to connect directly to tv )
3. No new PIP ( where you get overlay of secondary input)
1 REPLY 1
Sean_Mc
Hi Mike,
I would suggest a Reboot and an update of the Firmware.  You can find more details here. If this does not help then I would suggest a Reset of your TV.
Let me know if this helps.
Cheers,
Sean Mc
