All Streaming Apps Missing or Not Working
M0j0666
 This morning my KDL-32WD603 app's have totally dissapered. Can't even open the menu. I So we that some people had this issue last year was it identified  or solved?
I have rebooted roter and tv. Factory reset. Wired and Wi-Fi connection
Any more ideas?
Sony what's going on!
steveswest
All,
Sony have ammitted a problem!
[Edit by moderator: removed URL as the original problem has been resolved]
39 REPLIES 39
Rglithero
Me too...any response?
Noddy64
I have the same problem. Working fine last night on Netflix, put it on to watch it this afternoon, go on to the home screen, select apps, then nothing happens & it jams on that channel. Gone back to factory settings, rebooted router. Everything else working on wifi with no problems, But TV just works on the usual digital settlings. At a loss, everything up to date & all was good when I turned it off lst night. HELP ME SONY!!!!!
Xpressobn
I'm the same here with our sony bravia. Select All apps and nothing comes up and freezes the tele until I try and change the channel and then press the power button. Please someone solve soon. I was hoping to watch a film I'd rented again before my time was up.
Noddy64
My TV is a Sony Bravia
KDL-48WD653
I have now got the internet sorted on it again, but still not able to access apps &  when I try it just jams on the station. Fed up of trying everything. I have a freeveiw, Hatachi 42" in the bed roon that does not support internet accress, but is now 12 years old, never had a problem. So disappointed.... really need some help form Sony with this one I think. It apears to be a promblem for many of us & all of a sudden too. :sob:
frustrated1111
I have the same problem and have tried all the recommended fixes with no success.
I assume we have to wait for SONY to resolve their end?
krishankant
KDL-48WD653
I am also facing the same problem. All app is missing.
Pootle07
Did you find a solution I have the same issue at moment?
sonyTVsux
KDL-43WD756
Same problems.  Apps will not load at all.
Reset to factory settings and initialized personal details - twice.
Unplugged TV.
Nothing has worked.
Hannahbee
Exact same problem here too - same make. Factory reset, unplugged, reset modem, reset date/time - just nothing happens when I select all apps after pressing home, except it freezes the controls.
