- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Android TV - Bugs and Issues
Hello all
The aim of this thread is to collate all the issues that are currently outstanding and to provide feedback to everyone in this thread. This thread will be a work in progress and updates on various reported issues will be posted back here on the pages below.
Only issues that can be confirmed by multiple people will be posted here.
NOTE: For anyone experiencing other issues not mentioned here - can you please ensure that you factory reset the TV. Instructions are located: HERE
Update: Due to some TVs that will be on Marshmallow and others that will be on Nougat, this list will be separated into two (ATV1 and ATV2 - see below for model numbers for the difference). If the fault occurs on both versions of Android, it will be listed under both lists.
Current Faults (ATV 1 - Marshmallow):
- Lip Sync issues - see HERE
- [Re-Opened] IR Blaster issues - see HERE
- Restricted Profile - No iPlayer - see HERE
- Satellite Channels Re-Sorting Itself Automatically - see HERE
- TV Turning Itself ON - see HERE
- Bluetooth Randomly Disabling Itself - see HERE
- Info Button not showing all information via HDMI sources - see HERE
- No 3D Options in Action Menu - see HERE
- Crackling audio on high bass when using Clear Audio+ - see HERE
- Intermittent Network Connectivity using WiFi or Ethernet - see HERE
- HDD Recording - HDD not powering down - see HERE
- Satellite EPG: Lack of information - see HERE
- Custom Label for Inputs not quite working properly - see HERE
- Football mode with AV Receivers Issue - see HERE
- HDMI Handshake Issues interferring with other equipment - see HERE
- Not Retaining Picture Mode/Colour Temp - see HERE
- Un-responsive TV after being in standby for a while - see HERE
- Wide Mode unavailable - see HERE
- Juddery Playback on USB HDD Recordings - see HERE
- Double Overlay of top Info Banners - see HERE
- Delay in changing volume using TV remote to external audio system via HDMI-ARC - see HERE
- Video App - Aspect Ratio 2:35:1 displaying incorrectly (stretched) - see HERE
- Amazon Video - Lip Sync Issues - see HERE
- Favorites List in EPG - Closing when changing to external input or app - see HERE
- Amazon Video - Juddering Issues - see HERE
- Cannot grant 'write' permissions on USB Drives - see HERE
- USB Drive used for internal storage keeps disappearing - see HERE
- EPG fails to update is 'Auto Service Update' is disabled - see HERE
- 3D within 3rd party apps "Function not supported" Error - see HERE
- Info Banner - Not changing description from Now to Next - see HERE
- TV Randomly Rebooting - see HERE
- Netflix Buffering to 25% then freezing - see HERE
- WiFi will not connect on hidden SSID using 5Ghz band - see HERE
- All4 App - TV show restarts from beginning at end of first advert break - see HERE
- WiFi - Unable to connect when ethernet cable is connected - see HERE
- Amazon App - Un-pausing when daydream is activated Issue - see HERE
- Amazon App - Failing to correctly play first time - see HERE
- Volume Bar - Display Issues - see HERE
- MotionFlow issues on aspect ratios other than 16:9 - see HERE
- YouTube app (v2.0) - 4K Issues - see HERE
Current Faults (ATV 2 - Nougat):
- Info Banner - Displays randomly when using HDMI inputs - see HERE
- Colour Settings not being retained correctly - see HERE
Issues Resolved/Closed:
- [RESOLVED] Casting not working - see HERE
- [RESOLVED] Pop up message 'Screen Format' - see HERE
- [RESOLVED - Individually] Problems updating the Firmware - see HERE
- [RESOLVED] No 5.1 Audio from various apps - see HERE
- [RESOLVED] Error message: “Unfortunately, HbbTvLauncher has stopped.” - see HERE
- [RESOLVED] TV SideView - Netherlands - see HERE
- [RESOLVED] Auto brightness issues - see HERE
- [WORK AROUND FIX] Disabling Daydream - see HERE
- [RESOLVED] WIFI Issues - see HERE
- [RESOLVED] YouView: Discover showing year not title - see HERE
- [RESOLVED] Amazon Prime UHD License Error - see HERE
- [RESOLVED] YouView Disabled after 10 December FW update - see HERE
- [RESOLVED] Google Play Store crashes when trying to install apps - see HERE
- [RESOLVED] Google Play Store is Empty - see HERE
- [RESOLVED] Incorrect System Time - see HERE
- [RESOLVED] VEVO App - Adjusting volume stops playback of music - see HERE
- [RESOLVED] Image Stutter on BT Ultra HD & Sky Q Silver Boxes - see HERE
- [RESOLVED] YouView Sluggish and Unresponsive - see HERE
- [RESOLVED] Duplication of HDMI Input Sources - see HERE
- [RESOLVED] TV Guide flickers - see HERE
- [RESOLVED] Video App aspect set to FullScreen - see HERE
- [RESOLVED] Auto Picture Mode is not working correctly - see HERE
- [RESOLVED] Unresponsive Remote Control - see HERE
- [RESOLVED] YouTube LipSync issues - see HERE
- [RESOLVED] Netflix Issue (UI-800-3) with BT HomeHub - see HERE
- [RESOLVED] Disabled Wifi switches itself back on - see HERE
- [RESOLVED] Picture but NO Sound - see HERE
- [RESOLVED] Blank screen with sound - see HERE
- [RESOLVED] Bluetooth randomly switching itself on after being disabled - see HERE
- [RESOLVED] Amber/Green Lights Blinking after Marshmallow Update - See HERE
[RESOLVED] Customise TV Key greyed out when YouView is enabled - see HERE
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Volume Bar - Display Issues:
Problem:
Many people have been reporting some display issues with the volume bar upon pressing the volume up or volume down buttons on their remote control. It seems like there are two issues:
- A delay in displaying the changes (approx 5 seconds or more)
- A delay in displaying the changes (more than a minute or so) - appears to 'crash'. Further detailed analysis of a logcat of the crash can be found HERE.
Threads:
https://community.sony.co.uk/t5/android-tv/bug-volume-on-screen-display/m-p/2338944
Updates:
26-07-2017 - Issue has been reported to Sony. Any information received will be reported back.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Problem:
Some forum members have noticed that MotionFlow either doesnt work or not very effective upon playback of video content with aspect ratios other than 16:9. Basically in summary, the videos that have the black bars at the top and bottom are effected. Issue seems to happen on both ATV1 and ATV2 platforms.
Thread:
https://community.sony.co.uk/t5/android-tv/motionflow-issue/m-p/2352056
Updates:
27-07-2017 - Issue has been reported to Sony. Any feedback received will be reported back.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Problem:
YouTube has updated its application on the Android TVs to version 2.00.18.
- 2160p content plays at 1440p instead
- General perfomance issues (i.e. jerky, stuttery playback) - which seems to be the result of high-cpu load
- 1080p@60 also have stuttery playback and via Chromecast.
Reported by:
Kuschelmonschter - HERE and further info in his bugs list HERE
Michelasso - On Italian forums HERE
Quinnicus - Confirmed
Updates:
01-08-2017 - Issue has been reported to Sony. Any updates received will be reported back.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Problem:
When setting the colours to an acceptable level and then returning back to watch TV, upon changing the channel, the colour saturation appears to default to a level 10-15% above the level that has just been set.
Threads:
https://community.sony.co.uk/t5/android-tv/kd-43xd8305-software-bug-in-colour-settings/td-p/2247024
Updates:
07-08-2017 - Reported to Sony, any updates received will be posted back.
- « Previous
- Next »
