- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
							Android TV - WiFi and Ethernet Issues
Hi All
I have noticed that there are some people reporting issues with network connectivity.
Please reply back in this thread with your issue. Please also list your tv model and all relevent information.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thank you.
I already know about this.
My query is about the "...not guaranteed for this TV".
It is as if they say "... not guaranteed for anything working on this TV"
And then what is the TV that is "guaranteed" for 10/100mbps ?
Just haven't seen this before.....:smileyconfused:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It sounds like a standard disclaimer.
There not saying it will not work just they cannot guarantee a particular speed or connection
Sent from my iPhone
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Ok you are right
But this is what should be:
and not "no guarantees". A "healthy" network should be the their only mentioning....
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Just found out to top it all that I can't record when in youview so it needs to be disabled, disable youview, you can't get ITV and 4 players??????
Not good along with the LAN connection thing so I'm taking the TV back and will probably buy a standard TV and a £30 ROKU stick.
Shame as I used to rate Sony as a manufacturer.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there I have a Sony Bravia tv model num 55s8505c I bought it in January and had Internet on it since then but now it has stopped working I have tried putting in the password and trying to get the internet back on but it keeps saying I have no internet connection but my mobile phones and iPad and pic work off the router I can't understand why the tv won't work ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@Dundeeunited2010 - Try running the network setup again on the TV and see. Also, it might help changing the wifi channel in the router settings.
If that fails, a firmware update was released today - see HERE. Once updated, I would suggest a factory reset of your TV - see HERE for instrustions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Not sure if it's related, but I had some wifi connectivity issues that started following this week's update. Turned out that disabling IPv6 fixed it (I'm on an IPv6 enabled Sky Broadband line).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks il try that 👍🏻
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Okies thanks for that il have a play about with it see how I get on do you think if I hard wire it i.e. Tv to router this will help too ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there can you explain to me we're I find IPv6 cheers
