Audio Description - how to switch it off!
JofnaTV
Assistance please.....My Sony Bravia KD-43XE8005 which I bought just over two years from John Lewis has recently started giving me Audio Descriptions, which I do not want. I have read a lot of the messages here and have tried to switch it off but to no avail. It is becoming annoying and frustrating and from what I can see here many different Sony TV sets seem to have many different configurations?   I am finding it all quite baffling for something that should surely be a basic setting?  The software and firmware (?) are both up to date.  I have been into the settings menu (numerous times) and cannot see an on/off for Audio Descriptions and the one place it is mentioned is set to normal, as recommended in another post.  I have disabled the Auto Service Update and then enabled it again after checking for updates, again as recommended in another post. Our TV services are provided by Virgin Media.  I am in the dark and do not understand much of the 'jargon'.
Can anyone help me please?
Thank you,
John
LightFoot
Specialist
@JofnaTV wrote:
Thank you for your reply. I always watch through the Virgin Media box.  An external aerial is connected to the TV but not used.  John
Hi @JofnaTV   In which case you need to be talking to Virgin Media as it has nothing to do with your Sony TV ðŸ˜€ You need to turn off AD on your VM box.
https://www.virginmedia.com/accessibility/virgin-tv
5 REPLIES 5
LightFoot
Specialist
Hi @JofnaTV
Just to be clear, are you getting AD when watching Virgin Media or Terrestrial channels on the TV?
JofnaTV
LightFoot
Specialist
JofnaTV
That is great thank you very much!
I did say I found it baffling and I am now on my way to try this link!
Fingers crossed....
JofnaTV
Brilliant thank you, that is the answer!   Your help was most appreciated.
