BBC iplayer & itv player apps not playing
mkj1972
Hi
when I click on the BBC iplayer or itv player & 5 on demand apps they always comes up an error occurred try again later.
I am connected to the Internet & channels like YouTube play fine
any help would be appreciated
thanks
mkj1972
Thanks for all your suggestions everybody but I have now fixed the problem I turned of the tv at the mains for 5 minutes then turned it back on & now all the apps are working again!!
12 REPLIES 12
Anonymous
Not applicable
Hi mkj1972,
Could you please let us know which model television you own and if you have updated your device with the lastest firmware?
You can find information on how to perform a software update here.
We will then be able to check this with the relevant team for you.
Best,
Arthur
mkj1972
Hi Arthur
my tv is a KD-55S8505C
my software is up to date as far as I know
thanks Mark
cass_n
Hi Mark - are your apps also up to date?  Usually this happens when the firmware and/or apps haven't been updated.  Cheers, C
tractor9
Faults with FREEVIEW are caused by the weather conditions.so do not adjust you set.
It`s affecting some terrestial channelsIn some areas. it been stated by "FREEVIEW"
mkj1972
Hi c
yrs my apps are all up to date & the apps are still not working
mkj1972
Hi
im not using free view I watch tv on youview
royabrown
Enthusiast
YouView gets the Freeview channels, and was likewise affected by the high pressure,
But as we are talking internet players here, there is only one corner case in which the high pressure would be relevant - if it suppressed or obfuscated some or all your channels, necessitating a retune.
The itv and All4 apps won’t work unless they know where you are, for which they rely on your tunings. If the itv app determines (or erroneously thinks) you are in Scotland, you have to use STV instead for complete programming.
All Players use your IP address to check you are in the UK. If they think you aren’t, you won’t get anything. You might want to PM your IP address to the Community Managers here, so they can check it for that.
YouView Superuser, but not an employee of YouView, nor retained by them for this purpose. It's purely me speaking
mkj1972
GrahamR
I had that problem one day last week. The next day all was ok, I put it down to internet speed problems locally.
