Bravia Sync and Android TV
ramo990
Hello,
I've recently bought a new TV : 49X8308C and I've been trying to use Bravia Sync on a PS4 linked on the HDMI2 input.
I've Activated HDMI Device Link under System menu in the PS4 and when I go to the BRAVIA Sync device list in the TV menu, I don't find any item.
Is  this a known issue of the new Android TV sets ?
How can it be solved ?
PS: I also tried Bravia sync with my Internet provider STB and I can't find it either
3 REPLIES 3
Golfik09
I have the same issue, and whe I switch PS4 on, TV will not swtich to its HDMI port and not sees it as active.
I have to manually change the input to PS4 HDMI port, and only after 5-10 seconds TV picks up the signal.
I hope someone know what to do to enable it for PS4
keirlawson
I am having the same issue but with my PS3, my new Bravia KDL43w805c will not dtect my PS3 slim
rooobb
I've my W805C connected and managing an HTCT350, a BDPS5100 and an RDRHXD870 via braviasync. Working smoothly. Don't have a Playstation but I don't see any reason for it not working.
Which info do you have when you press the sync-menu button on the remote?
