Hi everyone
Im new here (great forum) and would like to ask for some expert help - I’ve reached a dead end.
I have a KDL-55W805C, upgraded to Android Nougat - I no longer have the tv tuner capability.
It doesn’t offer it as part of the initial set up, nor as an input, not under TV menu (no channel set up menu)
ive done a hard reset, reinstalled the firmware (by usb), cleared storage - no joy.
Any help would be great (fingers crossed)
Thanks
The TV tuner capability, by default or after a hard reset, is provided by YouView.
Can you see, and choose, that option on your menus?
As well you might be.
If it is still under warranty, I would suggest talking to the retailer you bought it from, who can either sort it for you, or swap the TV if it is faulty.
But can you post a screenshot here, so we can see what you see when you put the TV on?
Thanks again for this.
i have made a support request to Sony to see what can done - fingers crossed .
To give you the screenshot they should be available in this message
Many thanks
Apologies, I have to wait 24hrs before I can upload
ill post them tomorrow
Hi Royabrown
But - they are upside down!!!
Can you not scroll up above that Apps line?
Ny apologies- does this help?
