Disabled WiFi and Bluetooth, re-enable themselves automatically
profile.country.GR.title
MiCal1967
Contributor
I had noticed this a few days ago, but I thought it was my mistake.
Today had this issue again.
Cannot specify the cause or app. Re-boot is not the cause.
New notice:
Disabled WiFi is unfortunately enabled by simply entering Home Screen - Network Settings and WITHOUT selecting Wi-Fi.
Try this:
  • Goto Home Screen - Settings - Network - Advanced settings and set Built-in Wi-Fi to OFF.
  • Go back to Home Screen select Network Settings. Press nothing.
  • Go back to Home Screen - Settings - Network - Advanced settings and voila!!!! Built-in Wi-Fi IS ENABLED BY ITSELF!!!!
26 REPLIES 26
stevgil
Hello, I'm sending you the same piece as below in case you are able to help.  I know it's a bit late but I've just seen your ad and, if possible, would be keen to hear if you solved the problem of turning off both wi-fi and Bluetooth. I'm interested because I now want to buy a new Sony 4K OLED TV (55 inch) but I do not want wi-fi or Bluetooth, preferring instead to hard wire everything due to EMF. Now (Dec 2019) I see that both can actually be turned off but I wouldn't want to buy a TV where they keep switching back on automatically. I don't use apps, voice activation or any thing like that, just basic stuff as minimal as possible so perhaps there's something I could switch off or similar to prevent the switch on happening. Anyway, I thought I'd write as I'd be interested in your thoughts and whether or not you've made progress in your deliberations regarding your problems.
Many thanks
My best wishes
asrehma50
Hi
I have just bought sony 48 inch oled smart tv 2020 model. But this tv is giving out to much EMF. How can disable all the EMF's
Thanks
Win_88
Specialist
Hi @asrehma50
How do you measure EMF at home?
Win_88
asrehma50
Hi
you can feel the EMF from sony smart tv, because it attacks parts of the body when you sit for a few minutes in front of the tv.
regards
Win_88
Specialist
Not sure how objective that method can be considered. But if you let me know the model number of your TV, i'll help you disable any Bluetooth/WiFi connection if applicable.
Win_88
asrehma50
Hi
Thanks, my sony tv model is :
KD48A9BU
Sony Smart Tv 48" OLED
Need to know how to disconnect
The built in wifi/bluetooth emitters on the motherboard and still be able to connect the ethernet cable from tv output to router for internet.
Win_88
Specialist
Hi @asrehma50
I'm afraid I can't help you disconnect anything from the motherboard. Does this mean you already have them set to OFF in the settings?
Win_88
