With every other TV I've owned - Panasonic, Samsung, even Bush - you could select Favourite channels and set them as the default in the TV guide and in the channel selection.
Surely there is a way to do this with a Sony Bravia? Model is Xh81 kd43 8196
To explain, all I want is this - to be able to turn on the TV from Standby, press TV on the remote and see my Favourite Channels as the default. Instead I have to select Favourites anew every single time (from the options of Digital, Popular, UHD, etc.) I could understand if I was turning the TV off, but it's from Standby.
There MUST be a way, surely?
Unfortunately no, that's the way it is since long ago
