Firmware update to v6.6575
LightFoot
Specialist
This is a first for me, the TV prompted me that an update was available (KD-55XE9305). Normally I have to use the USB method to perform all updates. If there are any problems I will report back.
5 REPLIES 5
srimal1985
Hi
Did you do the Firmware update to v6.6575?
after I do the update, Seems my TV's Host name is no longer shown in the Router.
Tried both cable and wifi.
Please keep me posted.
LightFoot
Specialist
Hi @srimal1985   I performed the update immediately, no problems so I didn’t report back. The host name in my router BT SH2 exists and is exactly the same (Ethernet).
Joe_Dohn
Specialist
Hi srimal1985,
Have you tried clearing the cached data and resetting the TV (by holding the power button for ~5 secs)?
- J.D.
srimal1985
I did reset the TV using Power button and Volume Down button in the side of the TV.
But no luck.
Sent from my iPhone
Joe_Dohn
Specialist
Have you tried unplugging both your TV (disconnecting or unplugging external devices as well) and the router for 2-3 mins for them to depower?
