How do I turn off narration for blind on Sony Bravia TV
Blackagnes1
My Sony Bravia KD43X H81 96
has just started providing narration when I watch tv programmes. Please can someone tell me how to turn this off. Most online advice mentions buttons and search categories my tv doesn’t have. In fact my remote doesn’t even have a menu button. Any help very much appreciated, as this is driving me mad! Many thanks.
5 REPLIES 5
RottenFoxBreath
Enthusiast
Try an Audio button.
Might be part of the audio settings.
royabrown2
Hero
Xxxx
royabrown2
Hero
(Edit wasn’t working - please ignore the above).
@Blackagnes1
This feature is called Audio Description.
https://helpguide.sony.net/tv/gaep1/v1/en/01_06.html?hl=accessibility
You probably toggled it on by pressing Mute for too long, and if so, you should try pressing this again for just over 3 seconds, which will toggle it off again.
If not, look for it under Accessibility and toggle it off again.
Blackagnes1
Thank you so much - yes, that works! Do you know where the menu is hidden by any chance, as there’s not a button on the remote?
royabrown2
Hero
@Blackagnes1
Glad you were able to fix it!
For where the menu is, open the link I gave above, as this suggests the answer.
