IR Blaster controlling Sky+HD box
TraceyB1710
Can anyone tell me if Ir blaster is compatible with sky box in Ireland?
I've connected it but doesn't seem to be working.
1 REPLY 1
Pascale_F
Hi Tracey,
Which TV do you have? You might need to contact Sony Ireland Support about this.
I'm just going to try to find some answers for you. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
