Issues on KDL 50W809C after upgrade to Android 6
sebciu1
I did it.
Sony please fix my issues:
1. TV doesn't turn on (after when it was off more then 10min.) by the keyboard Logitech K400+
2. TV doesn't turn on (after when it was off more then 10min.) by the sony app Video & TV sideview
It looks like devices LAN, WiFi, USB r turn off after 10min when tv is off.
3. somehow tv it's turn on itself - sometimes
sebciu1
About connection by smartphone i solved myself to remove and add again TV in app.
To turn on by keyboard its impossible bcos USB is disable after some time when tv is power off.
4 REPLIES 4
Anonymous
Not applicable
Hi there
For issues 1 and 2, please ensure that you have 'Remote Start' set to 'ON' in the Network Settings area of the TV.
In regards to number 3 - I have had that once (a couple of weeks ago).  At current, this is an open issue on the bugs and issues list - see HERE
marmedin5
Me too, I tried everything called to Sony still waiting for the call
sebciu1
marmedin5
thank you!! it has now being resolved I had to set up again as new big issue off this off that plug this unplug, so complicated
