KD-55AF9 Bluetooth Question
MysteryMan99
I have a Sony KD-55AF9 and just tried to connect a Bluetooth gadget that will allow me to stream direct to my hearing aids.
This sort of works, although volume is a bit low!, but the issue is that it stops the audio playing back over the TV's speakers.
Is there any way to have the audio on both (TV and Bluetooth device)?
You want to output sound from the headphones/Bluetooth audio device and audio system/TV speakers at the same time
https://helpguide.sony.net/tv/faep2/v1/en/08-05_09.html
1 REPLY 1
