KD-55x8509c
iain-53
KD-55x8509c
Trying to find out if I can get Freesat on TV?
LightFoot
Specialist
Hi @iain-53
According to the specifications it has satellite tuners built in and the reference guide shows the F-type dual connectors. However you should note that it receives satellite signals but does not have FreeSat, which is a proprietary programme guide.
https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs-android-/kd-55x8509c/speci...
2 REPLIES 2
LightFoot
Specialist
Hi @iain-53
iain-53
Okay, thanks for getting back to me.
