KD-55XE9005 wont turn on
kaspert
My 2 month old TV will not turn on. There is a blue light at the bottom. help me out
4 REPLIES 4
IamNic
Hello @kaspert,
did you unplug your TV for a few minutes and plug it back in?
- Nic
kaspert
yes i didt work
AstroSmurf
Try factory reset. Unplug tv for 1 minute, then plug in tv. Press up arrow and hold, then tap power button on tv. If this works you should see reset option appear. Good luck
AstroSmurf
from what iv'e read the blue light may indicate something to do with WPS connection on wifi. Maybe turn of your wifi before starting up tv if it's connected this way to the internet.
