KD49XD7005 + LG Soundbar issue.
Phil_GT
hi all
hope someone could point me in the right direction for the issue im having
i purchased a couple of days ago a KD49xd7005 tv to replace a samsun smart 5500 series tv.
currently im having an issue with the sound bar, this is a LG soundbar which includes auto power on and off (when tv is on or off)
when i use it with the samsung it works fine, however when i use it with the Sony tv its as if when you turn off the tv, its not actually sending a turn off signal to the optical output port.
it also doesnt come back on proerly when you turn the TV on either.
the soundbar is known working fine so i dont think its that.
is there a setting i've missed somewhere to make the sony tv turn the optical output on/off with the tv?
any ideas would be muchly appreciated, as this is the only niggle i have with it (not that its hard to use the soundbar remote included)
2 REPLIES 2
Anonymous
Not applicable
Hi there
Interesting that two posts within 24 hours about the same thing :slight_smile:
See this thread:
https://community.sony.co.uk/t5/android-tv/lg-sh4-soundbar/m-p/2250739
Although, if you have a choice, connect the soundbar via HDMI instead of optical.
Phil_GT
hi there.
thanks for the link, however with mine it only has an optical input and aux for mp3 etc.
