Recently all apps have stopped working.
I have updated to software 8.216
Have unplugged Tv and router
Apps still not working
Get error message:
The system has encountered an error.
Please try again later. If the problem persists, contact Sony. <2200>
Seriously fed up with Sony
Hi @69mollers69 and welcome to the Community
If you have already tried a reset / disconnecting the
power for 2 minutes and reconnecting with no luck then its probably best you
contact Support on +44 (0) 2073652810
