Hi, my kdl-50w755c android tv keeps auto dimming. trying to watch walking dead and the dark scenes do an obvious light level adjustment. I have turned off the light sensor but nothing. It brightens up again when I hit the volume botton or something. the content is being played out of my sky box through HDMI. does anyone know anything about this problem? I have searched the forums and cant find anything...
I have same Issue With my only 3 weeks old kdl-43w8305. I didnt notice before the update last week, but it may have been anyway. Currently, I watch Homeland on Netflix, and in lot of Dark scenes, the edge of screen gets lighter (almost to a grayscale). Worst is the right side of screen.
Really hope, this something that can and will be fixed by an new firmware update, as this is very anoying and not worthy of the Sony brand. My 2012 Sony presents better pictures than the new one 😠
I fixed this issue by changing something in the picture settings. I'll check when home and report back.
As mentioned
If the TV picture dims too much:
Change the Advanced setting for Brightenss Black level enhancer SET to LOW or OFF.
Also: Turn the Light Sensor to off. Picture will be a lot brighter.
Is there anything on this TV that actually works properly as it seems like there is not?
I will say however that the picture is very good when its working properly.
Sad to say nothing else does!
Gonna check I am still inside my 30 day return but I dont think I am.
This is to confirm that the brightness variation issue is hapening also on model KDL-55W808C
My 55X8509G exhibits a similar problem. Watching an Amazon Prime film and a recored show off my HDMI Humax, almost every scene experience subtle (and sometimes not so subtle) change of dimming, depending on the scene. It was driving me mad and really ruined the film.
FYI I had turned off the setting advised to stop the sreen brightening when using the voulme button (which has worked).
ALSO has anyone had what I can only describer as a 'flare' that seems to come from the LED and fills an arc across the screen above it in greenish-white flare that lasts a second or so? It happened about 4 times during a 2.5 hour movie. Is this a new bug?
Up until I notice this problem I was really enjoying this TV and hadnt had any problems with the Android os. Now I'm very unhappy.
And to confirm so does my KDL-43W756C...
So bad I feel like taking it back...
Doing all the usual upgrades now but not hopeful this can be resolved..
Sony what is going On?
This worked for me. Thanks.
I've got the same problem with my KD-55x8509c television. The tv seems to be auto dimming especialy with Netflix 4k and dark scenes. I've turned off adv. Contrast but it also appears. What to do?
