Hallo, I have problem with my tv, it sometimes reboots, some day even several times, no mather which program you are watching (TV, Youtube etc.). Of course I did master reset to default factory settings, but with no change.
Has someone similar problem with this model?
Thanx for any ideas.
HI there
Not heard of this exact problem before, but some troubleshooting steps:
Give that a go, and see.
Hi, thank you for the advice, I'm doing exactly these steps and observing. I suspect mistaken router. But it is also fact that in the previous version of firmware was not problem.
So I'll try and let you know then.
Thanks.
