- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi i received a 55AG9 a couple of days ago and in pc mode game mode this is what happens when looking at certain angles on the right side of the screen.Is this not centered correctly? doesn't do it on all content.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Ok thanks it seems there is weird graphic glitches in battlefront 2 i should have known being an EA title nothing else seems to be doing it i shall try some other titles thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hello @AdrianA19761,
is it only there when you have your PC connected?
If yes, then I think your Graphics card is about to die or you are experiencing a weird graphics-glitch.
- Nic
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Update...
Scrub that it was the game and this morning the TV has failed after less than 3 days use.
Won't power on, red flashing light 4 times, unplug 5 mins, try to power up again it tries, the screen flashes 3/4 the way up near top then powers off again, taking it back to richer sounds today for a refund, getting the 55xg9505 instead, don't like the the motion on oleds.
