TerriNX72
Opera Browser
Please help me load Opera TV browser. I'm working my way through all settings. Network is ok. Modem is recognised. But in 'Server Display settings' message reads: Servers cannot be recognised. Please check the connections, press Options key and select "Update List". I have done this but still get same message.
My ultimate goal is to be able to see YouTube, which fails to load. Access via Humax box to all other TV apps works well except for YouTube. So I thought maybe I could download an updated YouTube app, but this would need Opera browsers to work!
My set-up is:
Sony Bravia TV: KDL 40NX723
Humax Freesat HD: HB-1000S
D-Link modem: Model DSL-3782
Any help would be very appreciated. Thank you
TerriNX72
Problem was solved by resetting Humax freesat box. YouTube TV app now loads so no need for Opera browser.
Thanks for your input.
4 REPLIES 4
rooobb
Youtube is not supported anymore on your tv, i'm sorry. Other apps as well
TerriNX72
Thank you for replying. I have a Humax HB-1000s connected to TV which gives me Freesat. Can I view internet through Humax and get YouTube? Viewing other TV apps through Humax works well but YouTube just hang there.
rooobb
If your has the youtube app it doesn't matter which tv you have it should work. If if doesn't you should check with humax why not or what you can do
TerriNX72
