Peloton App disappeared
Charl2810
Hi I have a Sony Bravia 2020 tv. I had the Peloton app working but it seems to of disappeared ? Anyone else experienced this? Thanks
3 REPLIES 3
Joe_Dohn
Specialist
I assume this is a downloaded app from the Playstore, have you tried checking whether it is installed or not?
It may have been uninstalled by mistake by someone, but it never hurts to update the TV software and re-download the latest version of the app.
Charl2810
Hi, yes it was a downloaded app that doesn’t seem to exist anymore? Have spoken to peloton and they say it is on android TVs?
I am updating the software on the tv to see if helps. Also the tv has stopped screen casting !
Joe_Dohn
Specialist
Could you share the model with us and make sure that you have the latest software version installed? It's also a good idea to check that the Time & Date settings are set to "Use Network Time" as other people have had similar Internet-related issues because of that.
