- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Problem connecting the TV via Media player and Receiver
hi guys
I have Sony X900F 65 connecting to the Receiver ( ONKYO 575E) with Media player (ZIDOO Z10 ) All link with HDMI CABLE My problem is that it dropping out for less than a second (disconnected)
This video while watching may explain the problem further because my English is not very good
Used hdmi 1&2 all same
HDMI signal format
-Standrad format ( not alot of dropping out just Once or twice While watching , In the content 4K HDR I did not watch it dropping out So far )
-Enhanced format ( alot of dropping out every 10 min )
I hope the problem is clear
Perhaps there are options to be made
I hope to find a solution
Thanks to all
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi ALOoONE,
I'll just see if I can find out anything, but someone else in the community may be able to advise in the meantime.
Thanks,
Pascale
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Ok thank you Pascale
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Not sure what to suggest as it seems the switching is to do with frame rate options, you could try experimenting with those, although even the resolutions look like you can change them to match the content being played.
The best thing to try it to make sure perhaps the resolution and refresh rate matches the content you play? For example if the file is 24fps make sure its set to 3840 x 2160p @ 24Hz. It might be a mismatch between what the player is set to and what the video is playing for example. If the content is a video encoded at 3840 x 2160p @ 50fps but you have it set at 60hz there is a mismatch. I don't know how automatic switching is on your media player is of it it forces those that output. This could explain the blanking. (or not)
I am pretty much guessing at this point.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Looking at the link you gave to the cable you bought, I see that Amazon offer free product support on it. If you bought it recently, it might be worth availing yourself of that support.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@ stormyuk
Thank you for your reply
I turned off the switch and the video played badly (not Smooth)I will try to choose dimensions and frame
